Idea Options
- Mark as Read
Mode activated when mobile device is connected to wifi router
Status:
Future Consideration
Submitted by
dannyknight
on
2018-09-11
09:56 PM
Hi Arlo
Could you have a mode that can automatically activate / deactivate when your personal device (mobile) is connected/disconnected to the same wifi router as the Arlo system?
It would be better and more reliable than using geofencing.
See more ideas labeled with:
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
