Idea Options
- Mark as Read
Graphically detect motion outside reach of the PIR-sensor
When the camera (Arlo Pro 2 in my case) is constant powered and is using activity zones it seems like the PIR-sensor is the primary trigger and then the activity zones is graphically analyzed from the camera image. This means that the motion detection still is limited to the effective distance of the PIR-sensor. Wouldn´t it be possible to graphically scan the camera image for motion within the activity zones without first being trigged by the PIR-sensor? This would allow motion detection further away,
/Håkan
See more ideas labeled with:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
