Feature Request - add mute notification button on the notification pop-up (android)
I use the Arlo app on android with the video doorbell.   Whenever I get a notification that there has been movement,  the notification box has the option to activate the siren or call 911.   Those two options are overkill for my needs.
When I get a notification of activity, most of the time it's not something that I am too concerned about.  For example, maybe the kids are playing in the yard, someone is mowing the grass, etc.  I like the alert to let me know they are there, but I don't need the continued notifications as they play or walk back and forth across the yard.    I would prefer to have the option on that notification to mute notifications instead of either siren or call 911.   If you can't add a third button, possibly have mute notifications and panic.  If you press mute notifications it would ask for how long.  If you press panic, it would give you the option for siren or call 911.
