- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Extending IR motion detection range - request for ...
- Mark as Read
Extending IR motion detection range - request for comment
Hi folks,
I wonder if it's possible to use a remote, battery or solar powered device to effectively 'extend' the range of the IR motion detection on Arlo cameras.
Idea: A device with an IR motion sensor, such as a battery powered security light, but equipped with an IR LED strobe circuit such as those used for operating small drones at night. The idea is that when the device senses motion it activates the strobe LED for a couple of seconds. The pulsing IR light should be interpreted by the IR sensor on the camera as 'motion' at quite a distance.
Use case: I have a long driveway leading to my front door and intend to place an Arlo camera above the door. The motion sensor in the camera should trigger recording when someone gets within 30ft of the door, but if possible I'd like to activate the camera sooner at night so that the Arlo person detection feature might generate a notification before the person even reaches the door. I'd like to place a cheap battery or solar powered motion sensing security light at the end of the driveway, out of WiFi range but within view of the camera, which would both illuminate anyone approaching on the driveway and trigger recording on the camera at a distance.
Is this feasible? Has anyone tried anything like this or confirm that this should work? For example, does anyone know whether a TV remote control, which effectively operates as an IR strobe when a button is pressed, triggers the motion sensor on Arlo cameras at extended range?
Suggestions and comments appreciated. Many thanks
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
