- Community Home Home
 - Community Browser:
- English
 - Arlo Forum Discussions
 - Arlo Idea Exchange
 - Disable recording when deselecting Animal Smart No...
 - Mark as Read
							Disable recording when deselecting Animal Smart Notifications
I just realized that Arlo's Smart Notification's feature (the ability to select animals, people, vehicle's, etc), only applies to Notifications, NOT the actual recordings. I would have thought it logical that if you wanted to turn off pet notifications for example, you would also want to turn off the camera recording? This would allow a camera to filter out unnecessary recordings and limit battery draining. I would assume this is not current behavior as the image processing is perhaps not completed in the camera, rather in the cloud? Therefore, the camera is 'dumb' to the actual motion...all it sees is motion and is triggered on or off...the algorithm is then applied to the recording and a notification sent (or not). Either way, having this ability would stop a lot of unwanted recordings and fiddling around with motion detector sliders.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
						Arlo Baby
78  -
						Arlo Video Doorbell
34  -
						Arlo Audio Doorbell
33  -
						Arlo Security Light
18  -
						Arlo Pro 3 Floodlight
15  -
						Arlo Ultra 2
9  -
						Arlo Pro 4
7  -
						Arlo Essential Spotlight
4  -
						Arlo Essential
1  -
						Arlo Essential XL
