Continuous Recording For Arlo Wireless
Hello,
I recently purchased Arlo Wireless with the intention to capture some high-rise littering that lands on my yard.
Unfortunately the recommendation from the salesman wasn't quite accurate, as I was under the impression that I have the option to choose between scheduled recording and motion detection. Apparrently not.
Problem is these litters are usually small items that I don't think it's going to be detected till it's very near (imagine someone throws it out form 15th floor) so motion-detection is useless in this case, as I won't be able to capture who littered.
Even if it's able to detect motion 15th-floor-high, it's not going to be able to capture in time from which window it flew out.
Wired camera is not an option due location I'd want to place the camera (otherwise I would've gone for many cheaper cameras).
I would really appretiate to have an option to schedule on-going recording. Eventhough this may result in battery lasting for just a few days, I would like to have that option if I'm prepared to bear the battery costs.
I think you should offer the user that option (place a warning on fast battery drain etc) for circumstances similar to mine.
Thanks in advance.
Comments
Nachoraj
Novice
I need the continuos recording mode is present also in wireless cameras. I know it would limit the batteries life seriusly but i need this option because i have installed them in a pharmacy robot and it is not possible at all a power wire, i know from people who would take this option if would be avalaible instead if changing the batteries frecuently
I think as mantener as possibilities the cameras have is better for everyone. Let us choose the recording mode including this one
Mantener thanks
