Arlo - need bulk edit method for Custom Modes
Add Mode / Edit Mode - Sensitivity & Recording time adjustments too cumbersome with multiple rules, and requires the user to make the same adjustment (e.g. Sensitivity) over and over again for each rule triggered by the camera --- Netgear needs to provide a simpler interface.
Problem: The current design is fine with 1 or two rules, but is cumbersome with more rules because you have to repeat the adjustment in multiple places.
Recommended solution: It would be simpler to have a matrix of controls with sliders, so all settings can be adjusted at one time - specifically only one sensitivity adjustment for each camera, and one recording duration for all devices triggered by a rule.  Checkboxes could be used to specify which other cameras are triggered.  In general, use a matrix of some sort to organize the rules and enable changes in a single view.
Illustration / Sample
Trigger Sensitivity Actions Record Duration
Camera A 85% Record on A, B, C, D 45 seconds
Camera B 50% Record on A, B, C 25 seconds
...etc.
Comments
Status changed to: Archived - Not Enough Votes
