App Features for Arlo Q Plus
1.  Ability to turn all cameras on/off with one click.
2.  Change the silly icons to you a give better idea of whether you're increasing or decreasing sensitivity of motion/audio detection.  After 45 emails and push notifications I realised that I had actually increased sensitivity rather than decreasing it.
3.  Ability to restore factory defaults or at least reset to defaults in App.  I'm tired of sticking paper clips in little holes for 10 secs.  Devices are not always located in positions that make this an easy task.  It was bad enough when you removed the software "reset to defaults" from your modems/routers.  Perhaps you could bring it back it back for them also.
