Add Arlo App Mode for Schedule
I primarily use the Schedule Mode because I don't want pesty notifications all day long. When I need to disarm or arm all cameras I can't go back to my Scheduled mode without setting my 7 cameras individually.
Thanks,
Pete
Comments
engpete
To Clarify, the app needs a shortcut button for Schedule Mode. There is currently only Arm and Disarm.
I'd like that, too, but the current implementation is to just go one step further (click on your base) and select the schedule again.
Edit: I do see you're referring to cameras that are likely connected to WiFi but this is the original wire-free camera section. You might want to consider use of a base or hub to connect your cameras which would also give you the ability to use local recording.
engpete
Thanks for your reply.
Yes, I am referring to Arlo Pro 4 cameras that are Wi-Fi. I'm not sure what you mean by "click on your base". I am not currently using a base or hub. I don't understand how a base or hub would give me the functionality I'm looking for.
What bases / hubs work with the Arlo Pro 4 cameras?
