@ShayneS After rebooting my base station, the Homekit option has disappeared from the base station settings menu in the Arlo app. It now shows up in the Apple Home app; however, I do not have a set-up code, which is why I've used the Arlo app to add them in the past.
Hi, i need to get a Homekit Reset Token, how do i do this?
Great, that worked, thank you very much.
Hi,
I get an "Uncertified Accessory" message when I try to add my Arlo Ultra 2 SmartHub to HomeKit.
It seems that the problem can be solved by requesting a HomeKit token reset, so can anyone at Arlo Support reset my HomeKit token as soon as possible?
Many thanks inn advance.
Just in case: Firmware is 1.16.5.6_911_3913242.
Hi @ShayneS ,
Can you please help with reseting my HomeKit token as soon as possible?
Thanks in advance.
I'm having the same issue, devices not being discovered. Can I get a token reset, please?
Beside this the quality of the video is clearly not 4K even if I set 4K local live (screen show 4K live but quality is for away from 4K)
Can you please help with a HomeKit token reset for my base station.
A111
Thanks!
Please reset the HomeKit token for both my Arlo Ultra and Arlo Pro Base Station.
Thank you!
Could you also send med a reset token?
Regards Allan
HomeKit is not working for me either. Can you please reset HomeKit token
@BabyFox @Rockcamera @AllanSilkeborg
I have reset you token. Pease reboot your base station and test again. Thank you
AppleTV
33 -
Samsung SmartThings
88 -
Security System
