Can you try again, I have reset your tokens. Please reboot your base station and remove/reinstall the Arlo app.
1-open HomeKit on my phone
2-open any camera
3-click on camera settings
4-click on bridge
5- click on remove bridge from Home
6- re-install the bridge follow steps install cameras
7- works perfect 100%
Thanks ShayneS to send me a reset token
Hi,
I am trying to add my smarthub to my HomeKit, I followed the instructions by the book.
I did that from the iOS app, then selected 'Home' then 'Room' then scan the QR code, but nothing is added (and I can keep waiting minutes in front of the Home app, it doesn't go through 😞
Please help. I suspect a token issue.
Great ! Now it works ! Thanks a lot 😁
@Mocajr66 I have reset your token, please reboot your Base Station and try again.
Can I please get a HomeKit token reset for my base station. Thank you.
Need a HomeKit token reset.
Hi could you please reset my token too.
Solved 👍🏻
Please reset HomeKit Token.
Hi,
My Arlo (VMB4000r3) cannot connect to HomeKit. Can you please send rest token to my base station?
Thank you!!
Hi Shayne,
Thank you very much!!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
