I have reset 2/3 devices, one of your baby cams is currently offline. Please reboot them and try again.
Could I get a token reset please—after updating to iOS 15 my cameras all went offline in the Apple Home app.
Have tried setting up again with the latest Arlo app, but just spins.
Cheers,
Yen
Model: VMB5000r6
I need another HomeKit token reset. My link to HomeKit has stopped working.
Thanks,
Scott
Can you also reset the homekit token for my Arlo base station. Thanks!
Again can you try and unplug your base station for 30 seconds or so and try again. Make sure you have the latest version of the Arlo mobile app. If you want, you can try are reinstall the app as well.
I have the same problem. I think I need a rest token too.
Could you please send one to my basestation ?
Thank you,
Alessandro
I'm also in need of a reset token - thank you in advance
Could you send my Arlo baby a homekit reset token?
Hi Shane, can you please reset my token? I've taken all the steps I can find on this forum to connect to homekit and I have also done a factory reset of the basestation but still no luck. Thanks.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
