@Comfortsins @JeremyH24 @JB7474 @Superhome @DvxAznxvb
I have reset your token, please reboot your Base Stations and try again
That worked!! Thank you for the help.
It appears I have the same issue, requesting a token reset. Thanks.
Can I get a reset token?
Hi @arjay67 @Superhome @Hanabata
I have reset your tokens, please reboot your Base Stations and try again.
I updated the app and firmware and I still have issues with HomeKit configuration (base station not discovered). Can I get a HomeKit token reset please for my base station? Thanks!
I too need a reset token please. VMB4000r3. Was working fine, then got the "offline" error and I made the mistake of removing it from Homekit. Now I'm stuck in the loop of doom on Discovering Devices.
Looks like a reset of my tokens will do the trick. I'm on the most recent app and firmware versions. Thanks!
I’m having the issue where when trying to setup HomeKit the discovering devices screen just search’s forever. Seems like people getting their token reset works? Thank you.
Hi @ShayneS, could I get a token reset on my base station as well? Thanks!
Hi ShayneS,
I need a token reset also. After updating to iOS 15.x it seems that my cameras all went offline with the Apple Home app.
Thanks,
Randy
Thanks for the very quick response ShayneS! That seems to have done the trick. I'm able to re-add the devices in Homekit again.
I am trying to add an arlo baby and its spinning on devices search. would a reset token help with that as well?
AppleTV
33 -
Samsung SmartThings
87 -
Security System
