Hello,
I'm trying to enable HomeKit and have no code underthe base. According to all the other messages here, I need a token reset. Can somebody help with that please?
Former NETGEAR Employee.
Disclaimer: Views and opinions expressed here are my own.
JeffKelso,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hello, could I also get a HomeKit token reset. Thanks in advance!
rk9,
Hello
i also need my base station token reset to reconnect to home kit! Thanks!
^^ disregard… after a few resets and deleting the items a few times I got it to pair again
My HomeKit connection dropped with the newest base station update. How to do fix that?
Kevin30376,
- It worked for a day then stopped working again.
Can I get another token reset? It was working then stopped again…
thanks
Kevin30376,
How do I request for a HomeKit token reset for myself? I have the same issues as everyone in this thread.
Reid4854,
Please reset the homekit token for both of my base stations. Thanks!
CoonsP,
I have reset my base station per the given instructions. However, there is still no “HomeKit” option (step 4) under My Devices. Is there anything else I can do?
Are you looking in the base station settings?
yes, I am in my base station settings.
Hi @JamesC,
can you send a reset token request to my station?
Model: VMB4000r3
Pro Base Station Three-LED VMB4000
serial: 4RC3947FA0488
thanks
What model base station do you have?
Michok, azza20
I have the VMB4000r3.
firmware 1.21.1.0_4300_898b168
Hi @JamesC,
I’m still unable to setup HomeKit, it’s still showing as linked in the Arlo app to a previous HomeKit Home.
Can I please get my token reset also
Reid4854, azza20, Xandervdw
AppleTV
33 -
Samsung SmartThings
87 -
Security System
