Can Go 2 Arlo cameras or whatever Arlo cameras record on site thru the Smart Hub or another device? Customer does not want subscription.
The Go 2 cameras are not compatible with the smarthub. They have a microSD card slot inside. But you do need to take down the camera and remove the card in order to see the recordings.
Ultra, Pro, and most Essential models can be paired to the smarthub.
Is the customer aware of the limitations with local storage and what other subscription features they'd be losing?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
