- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
I’m experiencing the same issue did all what the rest have done I bet it has to be with the token as well. If you could help me with that please.
javierfalcon,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Arhigh,
Hi James,
I am having the same issue with my VMB5000r5 Ultra 2 base station. Can you please resend the token?
Thank you!
Terry
Sonte_Cuco,
James,
That worked great! Thank you so much!
Nicksubs,
May I request a reset token please. Thank You very much for the help.
-Mark
MarkSA,
Thanks for your help James. I was able to connect.
Hi,
I am having this same error, can I get a token pushed to my smart hub?
Thanks,
daryl
Daryl-100,
Thank you. That worked great.
daryl
Dear James,
I am having the same issue with my VMB4000r3. Can you please send me the token? tks.
I James - i'm also having the same issue, please could you send the token to my device? thanks!
Kauyau, Rhodesy
Mtwilliams87,
My base is a vmb4000r3
Thank you!
Hey JamesC, is this still an issue? My VMB5000r5 (firmware version: 1.16.3.2_693_6cd3d19, no updates available) is giving me the same error when I try to connect to HomeKit. I submitted support request 41923674 yesterday but haven't received a response yet.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
