- English
- Arlo Forum Discussions
- Partner Integrations
- IFTTT - The plan assigned to the device does not s...
IFTTT - The plan assigned to the device does not support [animal] detection
When trying to setup IFTTT to perform a trigger [if Animal is detected], i get an error that states "The Plan Assigned To the device does not support [Animal] detection"
Not sure whey I'm getting this error as both the camera and my plan support this. Anyone else getting this issue?
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
I have the same problem
Tried to remove camera from the arlo account and added it back in. does not help.
I've also disconnected Arlo from IFTTT and reconnect, does not work either
I have opened an issue for the same problem in April, I have had a long exchange with the Arlo Support, provided all details requested and nothing happened - https://community.arlo.com/t5/Arlo-Pro-3/IFTTT-and-Arlo-detection/m-p/1859858.
Can you give us an update?!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
