@maxaf I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.
Thank you
Can you reissue token 1 more time? I have only 1 iOS device. I wanna make sure that this time I do a physical reboot once you confirm and hopefully it will work.
@Sjain1
Did you try reinstalling the Arlo app?
my HomeKit has stopped working after you sent me a token 2 years ago.
any chance you can help me again?
have tried all the usual, reboot, check for update, reinstall app etc.
it’s stuck on the discover screen
thanks
vmb4000r3
1.18.0.3-4035-d554faf
Thank you
Hi,
I had to remove Arlo from Home but now I can't add it again! Can you please do a token reset again? Thanks!
Hi, I had to reset HomeKit and now need to add Arlo again. Can you please a token reset? Thanks!
Suresh
Thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
