Brand new Arlo Pro 2 & base-station cannot connect to / discover HomeKit, out of the box.
I've been through phone-support twice since receiving my Arlo Pro 2 cameras on Thursday night, but am hoping I can expedite the solution as I'm now waiting for a Tier 2 support person to call me back as none were available tonight...
How the issue manifests:
After setting-up both Arlo Pro 2 cameras & Hub (VMB4500r2) via the Arlo app on my iPhone, I went to setup the HomeKit integration via the Hub's settings. However, I perpetually see the 'Discovering your device. Please wait.' screen instead.
Troubleshooting steps taken:
- Reboot Arlo Hub (via app & power-cycle)
- Reboot Arlo Pro 2 cameras (via app & power-cycle)
- Reboot home WiFi (via management app & power-cycle)
- Soft-reset iPhone
- Uninstall & re-install Arlo app
- Use second iOS device (iPad Pro)
- Restart Apple HomeKit Home Hubs (Apple TV, iPad Pro, and HomePod)
- Confirm all Apple hardware is up-to-date with software
- Confirm all Arlo hardware is up-to-date with software & firmware
- Confirm all devices are on same WiFi network
- Confirm all existing (25+) HomeKit devices are connected & responding
- Place cameras, Hub, and iPhone within inches of each other
- Leave iPhone on above 'Discovering your device...' screen for 30-45 minutes
Arlo support experience:
I've been on two different phone calls with Arlo support, which (to be honest) has not been fantastic. I've spent about 90mins on the phone on two different days, and spent about 50-60mins of that on hold. I've repeated all the steps numerous times, and the very first email follow-up I've received just tells me to follow the KB article on how to set-up HomeKit...
I'm now waiting for a Tier 2 support engineer to call me back 'within a few days' as none were apparently available tonight.
I've done plenty of my own research both here, as well as on the /r/arlo subreddit, and it does appear this is a known issue with a number of Arlo Pro 2 kits, wherein the Hub needs a new Apple HomeKit Certificate issued remotely, with many saying they can have this resolved once this is confirmed within 20mins.
I'm hoping that someone (perhaps the fabled JamesC of this support forum) can help me in resolving this...
Many thanks for any help you wonderful people can give!
Please can you reset my token, same problem as everyone else.
Having the same issue. Please send me a token reset request as well.
BLTN, rgallardo54
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I am still suffering from this problem and spent over 3 hours chatting with support. After a few days a tech name Fitz sent me an email asking my contact info so he/she contact me and I replied the request 3 times but still no contact whatsoever!! Is there some sort of internal documentation that shows employees how to do this? Seems like Arlo team just left me hanging in the air now?! Is there a higher tier tech that I can reach to? What's the point of contacting the Arlo Support Team when they won't even help???
Could I get that token as well? Thanks in advance. HomeKit quit about 2 weeks ago on me.
KravE,
Hi James,
panman91,
Thank you James, it worked!
I can't believe Arlo support just ignored me like this!!!
Ltuned,
I've requested an update on your open support ticket. An agent should be reaching out to you with an update soon.
I am having the same issue with HomeKit setup. Once I try to initiate the setup I get stuck in discovering your device please wait mode forever. Can you please reset me the same way you did the others? Thanks in advance.
Coronadelmar75,
Hi,
I’m not sure how this token works, bit I’m having the same problem with connecting. Could you help me out?
Thanks.
Thomas
Tdhmd, Thjuul
Hi James,
Thank you for your fast reply. I have reconnected my cables and switch - and restarted the base station. Still no luck. Any ideas?
Thank you.
Thomas
Thjuul,
Try again now. If your system was not connected when you made this request earlier, it would not have been able to receive the token reset request.
JamesC,
Can I get a token reset?
It worked like a charme!
Thank you for a great service!
helloimerwin,
Hi JamesC,
Can I get another token reset sent to my base? I will give it another try since no updates on my case whatsoever.
AppleTV
Samsung SmartThings
79 -
Security System
