Re: Arlo Pro 2, HomeKit setup issues
- Email to a Friend
- Email to a Friend
Please can you reset my token, same problem as everyone else.
- Email to a Friend
Having the same issue. Please send me a token reset request as well.
- Email to a Friend
- Email to a Friend
BLTN, rgallardo54
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
- Email to a Friend
I am still suffering from this problem and spent over 3 hours chatting with support. After a few days a tech name Fitz sent me an email asking my contact info so he/she contact me and I replied the request 3 times but still no contact whatsoever!! Is there some sort of internal documentation that shows employees how to do this? Seems like Arlo team just left me hanging in the air now?! Is there a higher tier tech that I can reach to? What's the point of contacting the Arlo Support Team when they won't even help???
- Email to a Friend
Could I get that token as well? Thanks in advance. HomeKit quit about 2 weeks ago on me.
- Email to a Friend
KravE,
- Email to a Friend
Hi James,
- Email to a Friend
panman91,
- Email to a Friend
Thank you James, it worked!
- Email to a Friend
- Email to a Friend
I can't believe Arlo support just ignored me like this!!!
- Email to a Friend
Ltuned,
I've requested an update on your open support ticket. An agent should be reaching out to you with an update soon.
- Email to a Friend
I am having the same issue with HomeKit setup. Once I try to initiate the setup I get stuck in discovering your device please wait mode forever. Can you please reset me the same way you did the others? Thanks in advance.
- Email to a Friend
Coronadelmar75,
- Email to a Friend
- Email to a Friend
Hi,
I’m not sure how this token works, bit I’m having the same problem with connecting. Could you help me out?
Thanks.
Thomas
- Email to a Friend
Tdhmd, Thjuul
- Email to a Friend
Hi James,
Thank you for your fast reply. I have reconnected my cables and switch - and restarted the base station. Still no luck. Any ideas?
Thank you.
Thomas
- Email to a Friend
Thjuul,
Try again now. If your system was not connected when you made this request earlier, it would not have been able to receive the token reset request.
- Email to a Friend
JamesC,
Can I get a token reset?
- Email to a Friend
It worked like a charme!
Thank you for a great service!
- Email to a Friend
helloimerwin,
- Email to a Friend
Hi JamesC,
Can I get another token reset sent to my base? I will give it another try since no updates on my case whatsoever.
AppleTV
Samsung SmartThings
34 -
