@dhanson99 wrote:
Has anyone gotten a response from Arlo on this? Seems like support folks are responding on every question on the board except the ones where it is crashing everyone’s XS Max. What gives??
Hopefully someone has logged a case with support and is not relying on the community site for resolution for a problem that significant. I strongly suspect Arlo management only pays attention to formal cases and the resolution of formal cases in the support system. This forum is primarily for user sharing and commiserating.
Both running iOS 12.1 (newest iOS)
But still **bleep**ing annoying! I have my kid on the arlo baby! And now its useless!
Open Google play store... touch the 3 horizontal lines in search bar....go to Settings...there you will find Auto Update apps..touch it and you will be given choices...select "Don't Auto-update apps"
Are they completely out of their mind? How can they not answer to this thread?
Arlo, fix your **bleep**in app!
Users should send this crap back and send a massive **bleep**storm to Arlo via Amazon reviews.
Flin (angry user from Germany)
Same here.
I just bought them today and it starts crashing on my iphone xs max 12.1.
Not only the app crashes but also it freezes my entire phone as the same time for a couple minits.
Unbelivable, get your software engineers together and get it fixed plz...
https://beta.apple.com/sp/betaprogram/
Thanks for the heads up!!!!
Many existing threads on this. It only happens on some devices. I have 3 and it only happens on 1. Open a case with support here to add pressure.
You can also try a different device and/or use a browser.
