Updated Arlo App on my iPhone with newest version 2.8(909) today, here are issues I have experienced:
- No notification whatsoever! This is a major problem!
- HomeKit worked partially. I have three identical 4000r3 base stations and idential cameras, all with latest firmware. Only two of base stations were able to added to HomeKit, and one of them still display as "uncertified accessory".
I am on iOS 13.1 Beta. For the reference, Arlo App 2.8 notification do work on iOS 12.4.1
Really frustrating to see that they have (apparently) fixed it on Android with 2.8.1 (release notes say it solves the issue of push notifications). I've just spent 40 mins online to Arlo support, and have been asked to try the various usual (bring a camera close, re-pair it, try switching to cellular rather than wifi, etc etc etc) ....
When I asked about 2.8.1 he said it is a known issue with iOS13 !!
And then told me there's no plan for 2.8.1 for iOS yet ??!?!
Not sure if I'm more frustrated that this problem hasn't been fixed yet, or the fact that 40 mins of my time was effectively wasted with pointless technical support steps (which seem generic from reading other similar experiences on the forum). Arlo, how about an announcement that 2.8 is broken & you're working on something - plus updates re progress ? Rather than trying to use the standard tech support script on every customer ?
Phew... feel better now !! 🙂
Arlo support has no clue what to do. Not sure about their customer base but 99.9 % probably don’t have the new iPhone11. Looking back I should have turned off all automatic updates for Apple ios’s and Arlo updates. I could have been happy with iOS 12.3 and Arlo 2.7. Not much we can do. The Web viewer has also got some issue and it show ....SDK version. What the heck is it doing with a software developers kit version?
Arlo Mobile app version 2.9 is now available for iOS supporting iOS13 and resolving the issue with push notifications. Please make sure you have the latest version of the mobile app downloaded from the app store.
For more information take a look at the release notes and knowledge base articles below:
Arlo iOS App - 2.9 - 19th September 2019
Will I need to reconfigure any settings after downloading the new Arlo app?
Why do I need to download a new Arlo app?
Why am I not receiving Arlo notifications on my iOS device?
The Arlo app was updated today in the iOS app store. New version is 2.9. Notifications are working and the app is fully compatible with iOS 13, according to the release notes. Yay!
FINALLY! Just updated and it seems working as before now.
For your references, I am on iPhone XS with iOS 13.1 Beta 4
I just test mine and the alerts on still not working. Running iOS Beta 4 😞
Well, tested several cameras at home and it seems alerts are working on both the updated iPhone-ios13. (Released today) and on my iPad (with iPadOS Beta 13.4). I haven't tested every feature but and so happy to see alerts are back!
Like many, I updated to the new ARLO app and deleted ARLO Legacy. Yesterday I implemented ISO 13...nothing, nil siltch. This has been nothing short of a nightmare since. I have (2) wireless camera on my driveway. One works "live" but WILL NOT record to library and the other was intermittent until this morning...now it is useless, as well. At least thru last night (2) other cameras seem to be working as designed / advertised.
I have gone thru all the motions (pun intended) as instructed on-line and nothing works. Tired of climbing up and the ladder, at 66 years old, to re-sync cameras. I have another system 80 miles away from my primary residence, and I have not received an alert from those (4) cameras since the Arlo update.
This update is a fiasco. I have these systems to help protect life and property and now they are absolutely worthless for that purpose. Ready to trash them...along with my subscription...and go to the competition.
What's worse is: I am not sure that ARLO really cares much.
As a side note: My daughter has ARLO, on my recommendation, and it has failed, as well.
Release a real fix or I am out.
The fix was real and works just as should for me. Maybe check to make sure you are allowing notifications in the iOS settings.
Mine is working as well on both an iPhone XS Max and an iPad Pro. Alerts started working right after updating to Arlo v2.9. No uninstall/reinstall necessary.
As I noted in my description I have completed multiple exercises, multiple times. It is NOT fixed for me. All PUSH notifications are active within the ARLO and ISO platforms. Again, I have (4) cameras on one system. (2) no longer motion detection / recording capability. All four cameras are set up exactly alike. Then there is the fact that I have had ZERO alerts from my 2nd location since ARLO issued the update. These systems quit working, in their entirety, under both Legacy and 2.9 Apps.
Glad its working for you but, many have not seen the success of others. I, for one, have a BIG investment in these cameras, extra batteries along with their subscription service and can't get thru to to their version of "customer service". Probably because they are overwhelmed.
In all the fairness, the Arlo app 2.9 for iOS did fix the notification issues. As many have reported it was working as expected. As you have mentioned that you have system does not working entirely, no detection of motion nor recording, that will more related to the system itself rather with app. Again, for most of us, the previous version of app broken the notification, but still works on motion and recording.
You may want to do a system reset to begin with. It is very much possible that during the diagnose process before with all the frustration, there are setting s been changed, especially with multiple areas. Rather than try to re-track every step back, it maybe easier just reset the system, if necessary, reset it completely and recreate the configuration again. It is not a very difficult process, and at least that you have a fresh start.
From app (2.9) and iOS 13, 13.1 (all beta levels), it appears working as expected.
"you may want to do a system reset to begin with. It is very much possible that during the diagnose process before with all the frustration, there are setting s been changed, especially with multiple areas. Rather than try to re-track every step back, it maybe easier just reset the system, if necessary, reset it completely and recreate the configuration again. It is not a very difficult process, and at least that you have a fresh start."
This has been done at least twice. Same (2) cameras work and the Same (2) cameras do not work. Agasin, one was intermittent until today. ALL conditions, rules and modes are identical. ALL show the motion icon as active. System has been taken down and reset. ALL notifications are noted as active.
Im getting double the notifications today
Hi,
I have switched to the new Arlo app 2 days ago (because i kept on getting the notification says that the old one will stop working on Sept 30). And ever since i switch to the new Arlo app. I stop getting my push notification. The mode is set to push notification and the phones (pixel 2 and my wife's iphone) are set to allow notification.
Just want to see if anyone has the same problem and what is the fix?
iOS13 and Arlo 2.9 App and no notifications. did receive them back as iOS12.4.1 and first version of the new Arlo app.
This has happened to me as well. I did all settings Apple recommended when I set up HomeKit, and it’s been working fine for a long time until I updated to iOS 13.1. I thought I resolved the issue by resolving all may devices and iCloud issues. But now that I have left again, I am getting the "No Response" through HomeKit. My devices are connected as I can control them with their specific app remotely...it's just that HomeKit won't allow me remote access at the most inopportune time.
I no longer get notifications. I have latest app and iOS 13.1, not the beta. This is a real problem and needs to be fixed immediately!
Model VMB3010r2
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
