Over the last two days my home station seems to change my time zone at midnight every day, this being a huge pain when scanning back over recordings. I have tried resetting on Arlo web site, iPad and iPhone but midnight strikes time zone changes again. HELP !
The lockup I have is that the base program thread gets held in a continuous loop and does not devote time to other tasks.
I see this when I use the web portal to restart the base it tells me the firmware is busy communicating to a camera.
Regards this firmware behaviour, it is consistent with the previous firmware they rolled back due to the same issues.
Personally, I have never seen that fault with mine, seems the base station issue causes different things to happen at different locations. If this was a "patch" to fix previous issues..hopefully third time lucky!
Got same problem with two base stations, keeps resetting to Pacific time and I am in uk😱 when this happens all cameras don’t record movement and there no records created for some reason yet I can manually record an image and it goes straight into library, fix it now as this is so annoying - is anyone from Netgear/Arlo listening to these problems?
@TomMac wrote:
Only lately due to a bug...I hear a fix is on the way
I hope you are right. Is this inside info, or just wishful thinking?
Our team is aware of reports that some customers may be experiencing an issue in which the time zone changes to the default setting of Pacific Standard Time within the Arlo app. We have investigated this bug and our team is working on a resolution.
We apologize for the inconvenience and appreciate your patience. We will provide you an update by 3PM PT/June 6, 2019.
Thank you,
Arlo Team
hello moderator
are you is your team also aware that base stations can go offline ? please upadate on this issue thanks
If the base was resetting to factory defaults, then why is the only thing that's changed the time zone?
It still remembers all of my cameras and other settings.
I suspect the answer will be the arlo server is changing the TZ. I just pulled my internet cable from the base just prior to my normal TZ time change time and then restored it after and the base came back normally without the change of TZ or the usual lockup.
This is awesome.
My arlo pro base Station has gone offline 3 times so far today. Every time the internet light goes off on the Base. The app just says getting status and although it doesn’t say offline there are no recordings or notifications. I can power cycle base to get it back online. Can you please provide an update is arlo tech support aware that base stations are also going offline with the time zone issue. And is this something they can fix with an update? Thanks. This has bean going on for weeks and we have tried everything we can. We would really appreciate any kind of update from arlo regarding this issue.
Thank you,
Arlo Team
The main issue is the base station is going offline on it's own multiple times a day. It would be nice if you also commented on this problem since you did not mention it in your post. 10 pages of people complaining of this and you only mention the time zone issue.
@Dannybear , You mentioned " ... I just pulled my internet cable from the base just prior to my normal TZ time change time ..". Out of curiosity, how have you determined "when" the TZ change is going to happen. For me, the change seems very random times... sometimes multiple times a day . thanks.
So many cases reported and, yet not even a single response from Arlo.
I think we need to take it to the press. Or form some sort of FB groups to mount pressure to Arlo.
At least they should fall back to the last working firmware.
Not only / not exactly at midnight. It seems random -- several times a day.
It is appalling that Arlo's "System Status" page is reporting "No Incident" over the past days, when in fact the system is chaotic!!
Everyone has their own standards. Arlo has theirs, we all have ours. Arlo thinks screwing with people's properties is fine, to us it's criminal.
Fair question to ask, my TZ change and lockup’s appears to be consistent at the same daily time similar to others mentioned in other threads.
I admit that I can’t know for certain since I don’t have the internet connection to the base active at the time obviously due to the nature of the test. It would be nice if others can test this in a similar way to confirm the same outcome. Just pull the internet cable for the base five minutes before and replace five minutes after the expected time it normally changes.
To explain why you and others are getting the issue more often at random times, i can only speculate.
Hello,
I'm also having the same issue. Almost daily I'll notice the time zone changes from EST to PST. Sometimes it'll still record, but I'll notice it's the wrong time. I also notice my cameras seem to go offline more often lately. I usually turn off the base station, wait about 30 seconds, and then turn it back on. It helps a bit, but it's not a permanent solution.
Currently running firmware 1.12.2.1_2798. I don't recall when the last firmware update was.
I hope Arlo sees this thread and fixes this issue soon!
Arlo should, at least, acknowledge this issue and give us their intention to solve the problem.
