Arlo Baby disconnected and won't reconnect
  • 2 Replies
  • 3441 Views
Retired_Member
Not applicable
Since this morning the Arlo Baby is disconnected and won't reconnect. It is UNACCEPTABLE that a baby monitor doesn't work!
Please remove this terrible mandatory connection between the Arlo Baby and your servers.
And fix the connection asap.
Retired_Member
Not applicable
I already did those things you suggested before starting this topic.
However without doing anything it started working after approx 50 minutes.
If the Baby is offline.... try and 1) turn off the battery ( under feet ) 2) unplug the power...
when re-plugged in the led should be amber ( then also turn on battery ) then the camera should auto resync turning led blue
Retired_Member
Not applicable
