How do I disconnect the base from the internet? Want to reconnect with my WiFi extender.
  • 2 Replies
  • 1344 Views
Bclifton
How do I disconnect the base from the internet? I want to reconnect it to my WiFi extender and can’t figure out how to do it. I thought it would be so easy. Help?
  1. Disconnect the base station's ethernet cable from the router
  2. Use that cable to connect the base station to the WiFi extender's ethernet out.
If the extender has no ethernet out, then you can't do it (you'll need to purchase a different extender).
Bclifton
Thanks. I should’ve known it wouldn’t be simple. And of course there’s no Ethernet out on my extender
  • 2 Replies
  • 1345 Views
