Cannot reconnect Arlo Baby
  • 2127 Views
CMEAKER
Had Arlo Baby for a number of years.  A couple of days ago Arlo Baby disconnected and cannot get it to reconnect.  It goes through the whole setup process, can hear the chime and light is solid blue, but app does not find the device.  I have been trying to reconnect for a couple of days now without any luck.
Has anyone else had this issue? Any advice?
Thanks in advance!
Have you tried a full reset ( hold reset for about 10 sec till led flashes )?
CMEAKER
Thank you for your response.  I have previously tried resetting, but it did not work.  I unplugged it again this morning and when it restarted it miraculously just worked.  Not sure why or how, but it seems to have sorted it self out.
don't forget, when really turning off, the battery under feet needs to be switched off too...
  • 2128 Views
