Camera will not reconnect after disconnecting
  • 1 Reply
  • 1154 Views
DavidJudd
My camera disconnected from our WiFi and I have tried to connect using the prompting. Any ideas? s but it will not. Battery charged and WiFi which is a 2.4ghz is work
Did you remove it from the account before trying to add it back?
You might also try the factory reset - opening the camera and pressing the button inside until the LED flashes amber (about 15 seconds).
