- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Failed to load stream with Google Home
I'm trying to link my Google Home Assistant devices (Chromecast and Google Home Hub) to my 3 Arlo cameras. I was able to link my Arlo Account in the Google Home app, and the camera names show, but when you attempt to open a camera it says "Not Responding".
I've tried unlinking and relinking my Arlo Account multiple times and it still will not work.
Why won't this work?
We've recently released a backend update which should fix the issue with streaming your Arlo camera(s) through Google Assistant.
If you're still experiencing this issue, please let us know.
Hey @JRD761,
Have you tried to reboot your Google Home Hub and see if that resolves the issue? You can view here on how to reboot your Google Home Hub: Reboot Google Home
My cameras will not stream either, original Arlo. I read on the site that the original Arlo is not support with Google Assistant?
Hey @48thRonin,
If you are trying to stream with your original Arlo Wire-Free camera, then it is currently not supported with Google Assistant. You can read it here: How do I view an Arlo camera with the Google Assistant?
i have linked my ARLO cameras to google home but i keep getting the message "failed to load stream"?? Anyone else getting this error?
I have not been able to link my Arlo pro 2 cameras to my Google Home app (either via the goolge home or google assistant app) since purchasing about a month ago. I have tried linking via IOS, android, through tablets and uninstalling, clearing caches, you name it.
The linking goes though the motions of connecting. I put in my Arlo details and then a white screen comes up and states that the accounts are linked, however it then tells me there is an error and the device is not in my google home screen. Google support are not able to help it appears. I have attached the log below. Is anyone ablento see where the issue may be?
I'm getting the same, the Arlo cameras are linked and showing up in Google home but whn I try to view the stream in Google Home, I get "Failed to load stream"
having same issue. rebooted, relinked several times. always get not connected or stream unavailable
I have 3 original Arlo Pro cameras, 2 Arlo Pro Q and a new 8" Lenovo Smart Display. Whenever I attempt to view video on Google Home or on the Lenovo I receive a "Not Responding" message. Any thoughts?
I linked my Arlo account with Google Home Successfully yesterday. However, I unlinked them that same day. Today, I went to link them back and I am having the same issues as you are. I press "add device" on the home app, then press "Arlo" and log in fine. I press the link button and I get the mwssage " linked successfully". However, when I press the blue "done" button on the top left corner, I get the Google rainbow wheel of death for about 30 seconds, followed by the notorious "something went wrong" message. The linking never actually happens.
I'm also getting the same error message "Failed to load stream"with Google Home app and Google Home Hub. I've successfully linked my Arlo account within Google Home setup and recognizes all 3 cameras I have but as soon as I try to view any one of them it fails. Looking forward to hear if there's a solution to this.
Once I logged in with the primary log in it connected fine.
what do you mean by secondary account details?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
