- English
- Arlo Forum Discussions
- Partner Integrations
- "Not Responding" message from Google Assistant; un...
I'm trying to link my Google Home Assistant devices (Chromecast and Google Home Hub) to my 3 Arlo cameras. I was able to link my Arlo Account in the Google Home app, and the camera names show, but when you attempt to open a camera it says "Not Responding".
I've tried unlinking and relinking my Arlo Account multiple times and it still will not work.
Why won't this work?
Hey @tarmistead,
Are you referring to the Arlo Wire-Free camera? If so, they are currently not supported with the Google Assistant and do not have an ETA of when they will be available on the Google Assistant.
https://www.arlo.com/en-us/landing/google-assistant/
I have tried the ‘sync’ thing but it says an error has occurred while syncing Arlo
Thanks!!!
OK, I think Arlo is fixing it.
It starts working for me now. It's a bit laggy at times, but at least it's able to stream the arlo pro camera streams to my Google Hub.
Won't link;
Won't sync;
Google Assistant- "Not responding"I
https://assistant.google.com/services/a/uid/000000698f1beeca?hl=en-US
It seems the Arlo api is broken for all 3rd party integration. It no longer communicates with Google or Smartthings. Was working about 50% of the time but nothing for past few days.
I purchased a very expensive 6 camera system based solely on the Google integration. Seriously considering returning for all Nest cameras.
So disappointed. Expected more from Netgear.
Just reboot base station and still doesn't work. Anyone else have this issue?
Did you happen to find out how to fix.
I think the last arlo update stuffed it up.
Hi all,
I am having issued with casting a live stream with my Arlo Baby. If i use the phone app, or any computer via web browser at my house (same network) i have a perfect live stream of my Arlo Baby camera.
When i try to use either of my 2 chromecasts or my google home hub to display the camera stream it takes an extended time to (from my feeling) "buffer" then it runs at a 40-60second delayed stream with extremely low quality.
I have read about the 2 versions of the camera stream, the "local" stream which is when 2 devices are on the same network and the "non-local" stream if you are viewing the stream from outside your home network. I feel even though my chromecast's and my home hub are on the same network it for some reason is using the "non-local" streaming method when casting.
When it comes to baby monitoring, between 40-60 seconds doesnt really cut it. Is anyone else experiencing this issue?
Thanks,
Has anyone gotten their Arlo Pro 2 to work with the Google Home Hub yet? Mine still refuses to connect and I've opened a ticket with the support team but still no luck so far.
I have got it to connect, but then video stops and restarts continually. It is also very slow to connect, the person at the front door is well gone before video streams.
Arlo are still working to resolve so I have my fingers crossed
I've gotten my Arlo baby camera back online. I think they fixed something on the backend. I was finally able to link my arlo account to Google Home in the app and then asked Google Home to sync all devices. I can now cast the camera to my TV using chromecast.
I'm still having the same issues:
Smartthings says: There was a problem trying to retrieve live stream URL. (Smartthings used to work but hasn't worked for about the last month.)
Google Home says: Not Responding. (When trying to view the live stream. I have tried re-adding and re-syncing all devices)
Sadly I have been following this post for a while and have had my system system the Pro 2's came out. It has got me to starting thinking about looking at other options with how long this has taken to get working reliably. I hope they get it fixed soon.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
