Collin_carter
My base is not discoverable when trying to connect to HomeKit.
Can you send me another token reset request to my base station?  Thanks,
415 REPLIES 415
Fin76177
I got connected to HomeKit now. Thanks for you help
ShayneS
Hey @Isacksenfamily
Can you give it one more try, I reset the token again.
Thank you
Isacksenfamily
I have two hubs. Living Room and Bedroom. Tried the power cycle on the bedroom hub. Still get wheel of death. Please advise.
ShayneS
@Isacksenfamily
I reset it again, try leaving it unplugged for a few minutes the reboot.
Isacksenfamily
Set for 5 minutes power cycled off. Same flow as attached on bedroom hub. Do I need to power cycle my home hub and next steps?
ShayneS
@Isacksenfamily
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
badstatic
Can I get a reset token sent to my base station as well please?
ShayneS
Hi @badstatic
I have reset you token. Pease reboot your base station and test again. Thank you
badstatic
New token did not work.  Got 'uncertified accessory" error.
Please advise.
thanks..
ShayneS
@badstatic
I have reset your device again, please unplug your Smart Hub for 1 min then plug in & try again. If you receive the same error, Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
RockyB_vl
Please send a token reset. First one worked for a few months, now I gotta do it again. 🤦🏻‍♂️
ebayboru
Hi - I am also having issues connecting my Arlo Base station to HomeKit. Would you be able to send a token reset request for my device also?
Isacksenfamily
My escalation to support has failed. Logs provided and cannot triage or identify issue. Has anyone been successful when reset token fails?
ebayboru
No I’ve not had my issue resolved yet. What can I do to resolve?
Isacksenfamily
Escalate to second level and demand resolution. Thus is a defect on the HK hub integration. They are ignoring me at this point.
ShayneS
Hi @RockyB_vl @ebayboru
I have reset your devices, please unplug your base station for a few minutes then try again.
Zobby1
Hi. Could you be so kind as to reset the token for my base station please?
Many thanks
John.
ShayneS
@Zobby1
svsmart
Hi There,
I am also trying to add arlo to Homekit but the HomeKit option is not visible in the settings, can a reset token be sent to my base please (understanding that is resolving everyone's problem here)
Cheers
sv
ShayneS
@svsmart
EdC1
I'm having trouble trying to pair my VMB5000 base station to HomeKit.  I'm getting a message that the ARLO equipment is "unsupported" and won't let me pair it with HomeKit. This issue is all over the forums and the rest of the internet, and the solution seems to be to have someone from Arlo push a new token to my hub. Would someone mind doing that for me please?
ShayneS
Hi @EdC1
rahdave_arlo
Please can you send a reset token request as my Arlo can not longer connect to my homekit
ShayneS
@rahdave_arlo
JM08
I would like to jump on the token reset bandwagon as well.
