No such luck. Still the same problem. It will keep on seaching for the device.
I have the same problem. Could you assist with the same solution?
HI @mfkdk @mg96 @BaneJackson @MEllzey
I have reset your tokens, please reboot your base station and try again.
Hello everyone,
I have a few questions below for anyone with their devices stuck on "discovering your device" when pairing with HomeKit.
Q. Were any devices onboarded (Paired/Setup) in HomeKit in the past?
**If so, have the devices been moved to a different location?
Q. Do you have any firewall setup?
Thank you for your patience while we continue to investigate this issue.
Hello,
To anser your questions:
Ever paired before: No
Firewall: Yes (Bitdefender)
thx
Sander (Netherlands)
I did a reset of my SmartHub but still not being able to find the cameras in the homekit. Once I enter into the configuration for the homekit, it stays looking for new devices an nothing is shown
Homekit reset token please.
I need a reset token please.
Please advise thank u 🙏
Arlo support agent reset token.
Power cycled the hub, still cannot connect to Homekit. I get the spinning wheel of death.
Was on homekit prior nothing changed on network (port forwarding or firewall). Ideas please, this is very annoying.
Did the agent not reset my token correctly?
Thanks for the token reset.
I've power cycled the hub and still have the same issues.
I have a homekit "set up" option (screenshot attached); however, when selected it takes me to the spinning wheel of death screen (prior screen shot).
Next steps?
AppleTV
33 -
Samsung SmartThings
87 -
Security System
