Hello
I have an older Arlo 2 Pro with no HomeKit pairing code listed on the base station. Sounds like a token reset would give me one. Is that true?
If not, how would I obtain a code?
thanks,
Vince
@Klopt I do not see a basestation on the account to reset a token. Is there perhaps another email address? If so please dm me that information. To use homekit you must have an Arlo SmartHub or Arlo Base Station (VMB5000, VMB4540, VMB4500, or VMB4000)
Hi, I also need a reset token for my base station (VMB4000r3). Thank you in advance.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
Can you please reset the token in my base station as well?
@BrookeN Could I also have a token reset please? Thanks!
:How do I connect my Arlo device to Apple HomeKit?
Having the same issue and would like to request a token reset request for my base station. Thanks
Hi, I also need a reset token for my base station . Thank you in advance.
I too need my HomeKit token reset
Hi, I Need too a reset token to mi base station.Thanks.
AppleTV
Samsung SmartThings
72 -
Security System
