Hello
I have an older Arlo 2 Pro with no HomeKit pairing code listed on the base station. Sounds like a token reset would give me one. Is that true?
If not, how would I obtain a code?
thanks,
Vince
@Klopt I do not see a basestation on the account to reset a token. Is there perhaps another email address? If so please dm me that information. To use homekit you must have an Arlo SmartHub or Arlo Base Station (VMB5000, VMB4540, VMB4500, or VMB4000)
Hi, I also need a reset token for my base station (VMB4000r3). Thank you in advance.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
Can you please reset the token in my base station as well?
@BrookeN Could I also have a token reset please? Thanks!
:How do I connect my Arlo device to Apple HomeKit?
Having the same issue and would like to request a token reset request for my base station. Thanks
Hi, I also need a reset token for my base station . Thank you in advance.
I too need my HomeKit token reset
Hi, I Need too a reset token to mi base station.Thanks.
Hej,
can I also get a reset?
Thanks in advance!
Seems like I could use a reset as well.
@richwklein it appears that your basestation is offline. As soon as you get it online please reach out to me and I can reset that token for you.
Can i have a homekit code aswell
Hello,
I am having trouble integrating my Arlo base station (Model: VMB4000R3) with Apple HomeKit. I have followed all the recommended steps, but I cannot proceed without the necessary pairing code.
Could you please send a token reset to my base station? I believe this should resolve the issue.
Thank you in advance for your help.
This gives you more information on what can be used with the Homekit:
https://www.arlo.com/da_dk/support/faq/000062279/How-do-I-connect-my-Arlo-camera-to-Apple-HomeKit
This link is broken, i can't see
https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-camera-to-Apple-HomeKit?cid=reddit&cid=reddit...
AppleTV
32 -
Samsung SmartThings
85 -
Security System
