flaquete,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I am having the same problem...Not able to add to HomeKit
Can I please get a new token and reset ?
Would you please send a token reset so I can set up HomeKit?
Wolverine_55, phatamerican, JPSmall007
Having had the exact same issues, could I get a token reset please.
Cheers
Thanks!
Hi @Bugsy6 ,
Do you still need the token reset? Please let me know and I will run it ASAP.
Thank you,
Mark V
L3 Tech
Hi @Bugsy6 @spatel9114 @dshoe3926 @nepher
Did resetting your base station token resolve this issue for you?
@JamesC can you please reset my token. Experiencing the same issue.
All systems go, now! Thanks again for your help.
@JamesC disregard my request above. Was able to get support to reset the token via live chat.
James,
I too am having the same problem. Can you please reset the token for me?
thank you
I’d appreciate if you can help me.
Thanks in advance
That worked - thanks!!
I am having the same issue (support told me they could call me back in 24-48 hours) any chance someone can resolve it here quicker?
I tried both wifi connection that are connected to the same router the base stations are connected to. I don’t know how I got the devices to show up in the first time.
Would reset the token work in my case?
I have reset your tokens, please reboot your SmartHub/Base station and try again.
Thanks, that fixed the issue
Hi James. I am having the same problem with one of my base stations. One synced with home kit just fine, the other fails with an unregistered device error.
The base station in question has the serial Number: *******A285C and MAC *******F938
thanks in advance.
That did it! thanks!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
