spatel9114
I’ve set up my VMB4000 Base station with 1 Arlo Pro camera and 3 Arlo Essential cameras, and when I try and configure HomeKit on the base station, it gets stuck on the discovering step and won’t actually connect. Can I get some help?
783 REPLIES 783
Jarklejam
This seems like a very common issue. I just set up my Ultra Smarthub and get the same “uncertified” error. Can I get a new token?
Jarklejam,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
applerama
Hello, can you please send a token to my account?
applerama,
kiranchitturi
Hi,
I am having the same problem. Can you reset my token as well?
Thanks,
Kiran
kiranchitturi,
Xapphire13
Hi James,
I’m having the same issue, could you reset my token also?
Thanks!
R1234
Hi James,
My base station is a VMB5000r5.
Thank you.
Xapphire13, R1234
meolsen
I hav a brand new kit with two Arlo ultra 2 cameras and a base station.  I get a warning that the it is an "uncertified accessory" and the set up fails.
I rebooted the base station, deleted and re-added it.  Same error.
johnb263
Also the same problem - please send token - model is VMB4000r3
Thank you
meolsen, johnb263
Jbt2079
Jbt2079,
Wilkmandoo
Hi - I am having the same issue. Can you please send me the token?
Model VMB4000r3
joshuajanderson
I'm having the same issue, can you reissue token please.
Wilkmandoo, joshuajanderson
Wilkmandoo
Hi @JamesC - I have rebooted (by removing and reapplying power) and followed the instructions on the link you provided.
I have now tried this three times.
Unfortunately (as per the attached screenshot) although my devices are "found" on each occasion it doesn't seem to progress past this point. Even it I leave it "discovering" for >5 minutes.
I have checked that there are no firmware updates available. I am running 1.16.3.4_3614_c289687
Any suggestions?
Your assistance is appreciated. Thanks.
Wilkmandoo,
If you're still experiencing an issue after i've sent you the token reset, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Fandy
Hi James,
Can you please sent a new token to my device for a reset? Thanks.
Fandy,
ffejnosliw
Can you send a token request to my base station?
ffejnosliw,
Motorsportuk
Hi James,
I am having the same problem with VMB4000r3 base (I have 2 bases, the VMB5000 is fine). Please can you send the token for the 4000r3?
Thanks Andrew
Fishbulb00
I have the same problem with my VMB5000r5 base station. @JamesC please send me a token. Thanks.
