- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
Hi James
could you please reset my token as well. Been having this issue and had given up until I stumbled across this thread. Thanks!
Hi JamesC,
I too am having similar issues connecting my base station to Apple HomeKit. Would it be possible to be sent the token reset as mentioned in this thread?
Thanks in advance.
javab0y, tomchalmers
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Would you be able to send me an token to, because my Arlo VMB4500 r2 basestation won’t connect to Apple HomeKit either.
Regards
Patrick
Thank you
Can I get a new token also please?
Pkehlet, Seamork, Zedrick
Hi James,
can I have a token reset request too? I’m not able to configure HomeKit.
Thanks!
AleO,
Hi James,
My arlo has the same problem, too. Could you help me to reset the token?
mine too need reset token
Mithril, Bob503
Farmerbs,
Can I also have the token? I am having the same issue with base station.
Manas0185,
It still did not work, can you resend. I have two base stations. I has worked the other has not.
Farmerbs,
I resent the token to both of your base stations, please let me know if you still experience an issue.
do i reboot then unplug, or just unplug?
Farmerbs,
A simple reboot (via the app) or removing and reapplying power should work.
I have same home kit issue for my vmb4000r3 base.
Please send the new token.
dezi,
Hi James, could I have a token reset request too? Homekit has not been working for me. Thank you for your help!
darkskylight,
Thanks James- works like a charm, very grateful for your time and help! 😊
AppleTV
33 -
Samsung SmartThings
88 -
Security System
