- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
I have the same problem. @JamesC please send me a token. Thanks.
Thank you very much @JamesC ! It's working now.
Thank you @JamesC it is working now
M also getting this same “uncertified” error, can I please get the same reset?
Ive been having this issue since I bought the system a couple years ago. Can I get the update as well.
Thanks!
Alex
TitoToivola, theomega, Hyacinthus, Inkslinginmofo7, tonywalker23
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Working good. Thanks!
mhugz,
I am not able to connect to HomeKit. My box did not contain any HomeKit setup numbers and when I try to connect the base station it says it that I have to update to the latest firmware
Hi @JamesC may i ask you to send also a token reset request.
I have this problem since a long time and just discover this topic that seem to solve the non certified accessory message
Hey @JamesC I need a token reset for my base station as well, thanks!
Hi @JamesC ,
I need a token reset as well. Suffering from the same problem as everyone else.
Can you help me?
I am having trouble with HomeKit setup. If you send a token would that fix the problem?
Ztm1094, isaaclimdc, StefanC, BIACS317
Hey James, is this supposed to help resolve the “Uncertified Accessory” warning? I’m able to “Add anyway” but is there a way to have these be certified?
James, we have not been able to setup our VMB000r3 base station with Homekit.
We tried for a long time when compatibility was announced, but have always gotten an error saying that the device is not certified. We eventually gave up. But I see here that you are able to send a new token and that fixes the issue. If you would be so kind as to do that for us, we would surely be very grateful.
Thank you in advance,
John
Al_Mo, KASHIFAhmed, Johm
AppleTV
Samsung SmartThings
79 -
Security System
