- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
Gerace, jmitchel20, Vrodfast, Arlod112, Gwdlynch
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
@JamesC Many thanks for this. It works perfectly now.
Gwdlynch,
Please reach out to me in a private message with your support ticket info (ticket number / email address) and I will escalate as needed.
I also have the same issue. Can you send the token reset to my base station as well JamesC?
brad10sc,
Im having the same problem... can you help?
flaquete,
James, I've had an unresolved ticket opened up for weeks on this exact issue. Could you please send the token reset to my base station. Thank you so much!
smian, kmcguire
Thank you James, that fixed it!
Inkslinginmofo7,
Hi James,
I’m getting the “uncertified accessory error.” on my basestation as well. Could I get a new token too?
felixsan,
chrisbrown1224,
Thanks for the help James, that did the trick!
Despite several attempts, I can't get the connection to work with HomeKit as it should. I get the warning that the base station is not certified.
Here's what I've tried:
* Restarting the base station
* Completely re-install my cameras and base station
* Getting a new token from Arlo and restarting the base station
* Tried to contact Arlo support but their site/chat is always down
Any ideas?
Thank you very much.
jqnchvz,,
AppleTV
Samsung SmartThings
79 -
Security System
