Brand new Arlo Pro 2 & base-station cannot connect to / discover HomeKit, out of the box.
I've been through phone-support twice since receiving my Arlo Pro 2 cameras on Thursday night, but am hoping I can expedite the solution as I'm now waiting for a Tier 2 support person to call me back as none were available tonight...
How the issue manifests:
After setting-up both Arlo Pro 2 cameras & Hub (VMB4500r2) via the Arlo app on my iPhone, I went to setup the HomeKit integration via the Hub's settings. However, I perpetually see the 'Discovering your device. Please wait.' screen instead.
Troubleshooting steps taken:
- Reboot Arlo Hub (via app & power-cycle)
- Reboot Arlo Pro 2 cameras (via app & power-cycle)
- Reboot home WiFi (via management app & power-cycle)
- Soft-reset iPhone
- Uninstall & re-install Arlo app
- Use second iOS device (iPad Pro)
- Restart Apple HomeKit Home Hubs (Apple TV, iPad Pro, and HomePod)
- Confirm all Apple hardware is up-to-date with software
- Confirm all Arlo hardware is up-to-date with software & firmware
- Confirm all devices are on same WiFi network
- Confirm all existing (25+) HomeKit devices are connected & responding
- Place cameras, Hub, and iPhone within inches of each other
- Leave iPhone on above 'Discovering your device...' screen for 30-45 minutes
Arlo support experience:
I've been on two different phone calls with Arlo support, which (to be honest) has not been fantastic. I've spent about 90mins on the phone on two different days, and spent about 50-60mins of that on hold. I've repeated all the steps numerous times, and the very first email follow-up I've received just tells me to follow the KB article on how to set-up HomeKit...
I'm now waiting for a Tier 2 support engineer to call me back 'within a few days' as none were apparently available tonight.
I've done plenty of my own research both here, as well as on the /r/arlo subreddit, and it does appear this is a known issue with a number of Arlo Pro 2 kits, wherein the Hub needs a new Apple HomeKit Certificate issued remotely, with many saying they can have this resolved once this is confirmed within 20mins.
I'm hoping that someone (perhaps the fabled JamesC of this support forum) can help me in resolving this...
Many thanks for any help you wonderful people can give!
Ltuned, Coronadelmar75
If the token reset did not resolve the issue, you may need to remove your base station from the Arlo mobile app and factory reset before trying again.
How can I reset my Arlo SmartHub or base station to the default values?
Hello, can I please get the token pushed as well?
Having the same issue.
Scone,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you
Guyincog, Lb123
My arlo pro 2 HomeKit stopped working a couple weeks ago. I have followed all kinds of steps but I cannot get the arlo app to rediscover the arlo base in HomeKit setup. Will a token reset fix this?
2hotty,
Hi JamesC,
Can I please have a token reset as well? I am also having the same issue setting up my Arlo system on Homekit.
Thank you very much for your help.
sc1683
sc1683,
I'm having the same issue. Can you send me a token reset request too?
Rich
I am having the same problem, I cannot connect my Arlo to Homekit and get the message "Discovering your device. Please wait." Can you send my new base station a reset token? I have two base stations, one is a new VMB4500r2 and I have a VMB3010r2 with older cameras on it.
Thank you,
-Peter
I have the same issue, can I get a token reset to try again to my homekit working?
Hello,
I think I might need this token sent my way too. When trying to setup my Arlo Pro basestation with HomeKit, it just gets stuck on the Discovering page. A while ago it stopped working in HomeKit.
Thanks in advance.
Aaron
Could I receive that token as well
Richiesips, peterp100, MDondi, Aaron323, tbraswell2
Great stuff. Thanks James.
Can I get a token reset request? I try connecting my base station to Homekit and it keeps saying "Uncertified Accessory".
Thanks. I should have clarified that I've already tried that. I removed the base station from my account, performed a hard reset, reconnected everything and I'm still getting the error.
thank you very much, now it is working and I am able to use homekit
Can you please send a token reset Request to my basestation.
I have the same issue with HomeKit.
Best regards,
Fredrik
AppleTV
Samsung SmartThings
79 -
Security System
