Can I get an token reset for the two SmartHubs associated with this accounts email address?
Can I get token rest for base station. Stuck on discovering Pro SmartHub VMB4540
Good morning could you reset my HomeKit token please
Mando-23, Jbon72
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Need a token reset too
Thanks that seems to have fixed it. Thanks for the help
What do I need to do to request a token reset for my HomeKit integration?
Brodie1225,
Thank you for your help.
I need a HomeKit Token reset.
Sheawill,
Hi could I please get a token reset for my Arlo base station as I can't get it to link to Apple HomeKit.
Thanks in advance
DaveArlo27,
I have the same problem. Getting stuck discovering deviced for HomeKit with my smarthub vmb4000.
Can I get the token reset that seems to solve the problem? The hub is associated to this account.
Thanks!
James thank you for doing this. It sorted it out perfectly and so happy to have this now linked again.
m have a great day.
Joan_LaCuquera,
Would you reset mine as well as there is no option to connect. Thanks
Could you please reset my base station?
C001, Gemelox
Just moved into a new house and my base station can no longer connect to Homekit. I've read other posts that I need to have a token reset sent to my base unit. Can someone please help.
Hello, maybe this account has a problem, could you please also reset the token for this account.
I’m clearly doing something wrong but can’t work it out.
I’m running Arlo secure app version 4.0.1 (5272) with a VMB4000r3 hub. Trying to setup HomeKit without a setup code per theseinstructions. The token has been reset. When opening the Arlo app settings > my devices > base station there is nothing about Home app. The only options are time zone, flicker adjustment, paired devices, local settings
Still having the same issue
CNSL, Cinisli
C001, Gemelox
You may need to factory reset your base station and re-onboard as if it were new. Take a look here: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
I did the factory reset. Issue is the same
AppleTV
33 -
Samsung SmartThings
90 -
Security System
