HomeKit button missing
Hello Arlo team,
I got the Arlo pro 2 and I cannot find the code to pair it with HomeKit. I was looking at the base station or instruction and nothing. I noticed in other posts that you guys do a reset token and that provides what I need to have the HomeKit button available. Could you guys do that for us ?
base model: VWB4000
Thank you for the help,
-LA
Hi @Lewis33
Have you tried performing the steps in this How-To article?
https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit
Hi ShayneS,
Yes, I tried those instructions. Specifically the part: To setup an Arlo device without a setup code.
But then I don’t see the HomeKit button. I can see my Arlo pro base, all my Arlo pro cameras as paired devices and local storage. So probably it needs to be added through a software update or the method that someone mentioned as “reset token”. Please let me know what else is possible in this case to get them added to HomeKit.
Thank you,
-LA
Can you try removing and re-installing the Arlo app?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
