creekside6918
Can I get an token reset for the two SmartHubs associated with this accounts email address?
317 REPLIES 317
ShaneMS
Hi! i’ve been having problem discovering/connecting Arlo Pro/VMB4000r3 to Homekit as well. Would you also please reset my token, if that’s possible? I just requested on 9-3-2022 and it worked fine for two weeks.
Dcl01
How can I get token reset for my hub?
ShaneMS,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Retired_Member
Not applicable
Can I get a homekit token sent to my VMB4000r3 base station please. Thanks
jupiterfish
ios16 took away access please send a reset token to my hub......any idea when we can do this ourselves?
ziplobob004
Hi could you also do this for me? Having the same issue.
Piccacircus, jupiterfish, ziplobob004
ranaakel
hello, can i also get a token reset? i'm not able to add my camera to HomeKit?
thanks!
ranaakel,
wingy3181
Could I also get my homekit token reset as well?
Nanab702
Can I get a token reset for the SmartHub associated with this accounts email address?
wingy3181, Nanab702
LBosson
Never mind. I'm good.
Johanpeter
Please send me a HomeKit token reset.
Sincerely Johan
Mikes_arlo
I am having problems connecting my VMB4000r3 base and need a token reset also.
Mikes_arlo
I am having the same issue. Can you send a reset to my base station also? It’s a model VMB4000r3.
Johanpeter, Mikes_arlo
Mikes_arlo
Thank you sir. It is working now.
Mocajr66
Mocajr66,
Mocajr66
Thank you, works perfect ✅
JKASHCROFT
Hi James,
can I get a token please
JKASHCROFT,
Roslan
i need a reset token (again, this is my 5th time!!!)
will there be any more strategic solution for this? this is so frustrating
Roslan,
