Can I get an token reset for the two SmartHubs associated with this accounts email address?
Hi! i’ve been having problem discovering/connecting Arlo Pro/VMB4000r3 to Homekit as well. Would you also please reset my token, if that’s possible? I just requested on 9-3-2022 and it worked fine for two weeks.
How can I get token reset for my hub?
ShaneMS,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Can I get a homekit token sent to my VMB4000r3 base station please. Thanks
ios16 took away access please send a reset token to my hub......any idea when we can do this ourselves?
Hi could you also do this for me? Having the same issue.
Piccacircus, jupiterfish, ziplobob004
hello, can i also get a token reset? i'm not able to add my camera to HomeKit?
thanks!
ranaakel,
Could I also get my homekit token reset as well?
Can I get a token reset for the SmartHub associated with this accounts email address?
wingy3181, Nanab702
Never mind. I'm good.
Please send me a HomeKit token reset.
Sincerely Johan
I am having problems connecting my VMB4000r3 base and need a token reset also.
I am having the same issue. Can you send a reset to my base station also? It’s a model VMB4000r3.
Johanpeter, Mikes_arlo
Thank you sir. It is working now.
Mocajr66,
Thank you, works perfect ✅
Hi James,
can I get a token please
JKASHCROFT,
i need a reset token (again, this is my 5th time!!!)
will there be any more strategic solution for this? this is so frustrating
Roslan,
AppleTV
33 -
Samsung SmartThings
88 -
Security System
