Can I get an token reset for the two SmartHubs associated with this accounts email address?
Sir_rey,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Could you please reset my token. New Base Station has the same problem. Thanks.
Mark...
Good Morning, I am also requesting a Homekit token reset to the system and hardware associated with this email.
Thank you for the support!
MukeMan, groogruxdave
Thank you. Things are already back up and running!
Gibledan17,
Hello Community. My Arlo base station and cameras have dropped off my Apple HomeKit again and cannot be re-added… can you please reset the HomeKit token? Arlo Pro 2
Dayln,
Can you also send a token reset for my base station? Thanks
Hi,
Can I please have my token reset? Issues when trying to add my base station to homekit.
Thank you
Ey up! Can I please have a token reset? I'm seeing "Unable to Add Accessory" & "This accessory cannot be used with HomeKit" when trying to add the Smart Hub to Apple Home Kit. Thank you! Ben
KrasavchiK, areyescarvajal, benjfletcher
Could you reset token please?
Hello Arlo!
My Arlo Ultra SmartHub can't find Homekit at home.
Could you reset my Homekit token please?
Thank you
Mocajr66, pezzos69
Hi there
can I get a token reset. HomeKit is stuck on discover and can’t find my camera.
Thank you!
It works now!
Please, reset the token for my basestation too.
Jasonwright285, AndB
Hello. Can I get a token reset as well? I am unable to discover my hub when adding to HomeKit.
Thank you.
JohnR007,
Thank you so much....that solved my issue.
Works perfect, thank you.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
