Hi I have just got the new iPhone XS max and it is synchronised to my cameras but it will not play my library videos but will play live events can you help please
From my chat with support:
"I talked to the technicians and the issue with Iphone XS and max regarding the recordings is an ongoing matter."
"I believe that it will take a bit more than weeks to have it solved. However, as it`s a common issue and somewhat new, the engineers are working hard on that, meanwhile Sir, we recommend you to use the app from another phone or the Web page from your computer."
One of the replies states that the ARLO Pro videos will play on the iPhone Xs....is this correct??? Can anyone else confirm this?
Z
Yes, the ARLO Pro H7 video works with Iphone X.
my orginal Arlo cameras do not play video on my Iphone X. I have to download them to Google drive to view the video.
Alro needs to fix this soon!
Has there been any update from Arlo about when this will be fixed. I have tried to contact them a few times but the chat doesn't work and no one is there to answer the calls
XS Max on 12.1 beta 3
Has been happening since day 1 of XS Max.
iPhone 6S running same beta 3 logged into same iCloud and Arlo account- all videos play fine with no crashing.
I have an iPhone Xs not Max and am having problems too. Not working with new Arlo Pro 2 and base station. I have 5 cameras it works on all my other iPhone and iPad devices.
I have 3 Arlo camera's, we access our library through IPhones. I had a Iphone 6 S that I just traded in for an IPhone X Max. All settings have been transfered from my old phone, but now when I get a notification, my new X phone shows the ie: person walking up to my door but there is No motion detected. All three camera's are set at 80% motion, but I see no motion, ( the person walking up to my door) just a snapshot of the person first coming into view. Has Arlo up dated their software for the IPhone X Max? My account on line and my son and wife's IPhones show motion, as my old phone did before. Thanks for any feedback......
Arlo is aware of issues with the App on the new Iphone X models. My understanding is that they are currently working on a fix. In the meantime you can use a browser to check your videos
https://arlo.netgear.com/#/login
We know that they are aware of the problem, but having the problem for almost two weeks is unacceptable.! The system is pretty USELESS to me for almost two weeks that i am away from my house not able to see nor watch my recordings!. What kind of support is these!. My old IP foscam baby cam is working on my iphone Xs max but this expensive arlo system is not?. Thats all i can say.
New Iphone Xs and Xs max problems, recorded videos is not playing on new Iphone Xs and Xsmax, but older iphones below Iphone Xs it works fine. Firmware is not the issue, some people says its a Graphics or video format related, problem is unresolve for almost or more than two weeks already..
So frustrating to try and play back when you need !
Arlo any updates yet ?
I do not necessarily think that it is not compatible with ios12. I have the XS Max and an iPad Pro. The playback is not working on the Max but it ois on the iPad Pro. Both are running ios12.
I have the same issue after updating to iOS12.
The video is not playing if I am using the app.
The bar is running but the image stays the same.
However, it works with my browser.
Reinstalling the app does not work...
any suggestion?
When is your system going to be updated to the work with the new iPhone.
My videos won’t play back on my iPhone through the arlo app. I can live stream though. Lost confidence in this product.
This started happening recently where the camera goes into recording mode and the picture freezes. When I am trying to access the live video feed, the picture is often frozen too and ai can’t view what I should be seeing. It didn’t happen the first few months I had this camera. Does anyone know what the issue is? My ioS app is up to date.
I am having the same issue, did support ever find a fix.
ever since I got my new phone (iphone xs) there is no motion on the playback of the video? i have tried to chat with arlo but that enver works...anyone have a fix or know how to let arlo know that needs to be adressed?
I have the same issue with iPhone XS. Recorded videos look like they are playing in the app, but they are stuck on the first frame. It doesn't appear to be an issue with IOS 12 as my iPad Air 2 running IOS 12 is working fine.
