I would expect this from other companies but from netgear???? Think it's time to get my money back!!!
OK so we finally get Arlo which we were excited about. We have 3 people in our house and well this system should be able to be armed and disarmed when anyone of us comes and goes.......or so you'd think.
NoHelp, SayWhat?
Set up IFTTT:
IF first family member arrives HOME then disarm arlo (Using life360 and arlo)
IF last family member leaves HOME then arm arlo (using life 360 and arlo)
3 IPhones set up with life 360 which have been working for the last 2 years
Member #1 comes home alone - Arlo disarms
Member # 3 comes home alone - Arlo disarms
Member #2 come home alone (the member that set everything up) and we have motion alerts going off left and right.
Yes, I set up everything the way it should have been set.
Search for Support number.... can't be found but find "Live Chat"
First support person is of no help and disconnected
Second support person gives me phone number and advises me to set up Geofencing and walks me through steps. Tells me THIS WILL WORK!
Call Support (Speak to someone in the Philippines ....... WHAT?? No USA Support????) And after being on hold get disconnected
Member #1 comes home alone - Member #3 gets 14 motion alerts even though the app says that member #1 is "IN THE ZONE" which means the system should have disarmed. Nope, Not my Arlo!
Look online for the Support chat and it's nowhere to be found but today, the phone number is there (crazy)
Call Support again.... yes, another person in the Philippines (nothing against Philippines but why no USA support???) This person knows nothing about how to fix this and suggests that I (member #3) remove myself from the system all together (Take my name, number, everything off the website, take the app off my phone) and this should help...... Ummm..... WHAT????
So I have to completely remove myself from everything just so I won’t get any alerts on my phone? Instead of someone coming up with a way to arm and disarm this system when different members of the family come and go??? Nope, not working for me!!!!! Support person asks me if I mind being put on a 5-7 minute hold? Um.... again... WHAT???? No. Im not going to wait 5-7 minutes.
Yes, Support person puts me on hold anyway and there I sit for about 15-20 minutes listening to some horrible music when CLICK....... Disconnected!
Can you even imagine how happy I was at that moment???? Yea, not very happy.
So here I sit, with all three members in the house and my phone flashing on and off.![]()
GEOFENCING AT HOME IS NOW HOME MODE
GEOFENCING AT HOMOE IS NOW AWAY MODE
MOTION DETECTED ON PORCH
MOTION DETECTED IN LIVING ROOM
MOTION DETECTED IN BASEMENT
Posted this on an alternate thread, but thought i would share here.
As of yesterday geofencing started to work with no changes or modifications. Both iPhone 6s using latest version of iOS are showing the correct location status changing status when both phones have left the area. Noticed there was an Arlo app available this morning v2.4.8 but fix apprears to be working regardless of new app version installed.
My two cents... on the phone name. I've got underscores in both phone names and has been like that since i've brought my arlo's online. I wouldn't worry about changing the phone names.
The geofencing started working on the IOS app (around yesterday). When we enter the security perimeter, push notification is received that "we have entered the Home Geofencing Zone" and the geofencing mode is updated correctly so far yesterday evening and this morning.
However, geofencing is still not working properly with the Andriod (Samsung) device yet. It doesn't update the status and it kept on showing status as unavailable. Tried to toggle (disable and reenable) the location on the samsung and made sure that Arlo is excluded from power save and made sure that Arlo is running at the background. Nothing seem to work.
Do you have a link to that App? Did not know there is a different app that also works with Arlo hardware.
Crap the Area Arm and Disarm only works with IOS and not Android. 😞
@Snn5wrote:
IFTTT location does not work with Android.
Works for me, installed it last night, it properly activated Arlo as it should (Android) when I left home today.
Will see how it behaves when I get back home, but this might be the only reliable workaround for as long as Arlo doesn't get their geofencing done properly, sad to need that as a viable option for a failing feature.
And sessions timeouts are irrelevant here as ifttt logs on to Arlo web on its own to switch the state.
JP.
Just got back home, ifttt just did what it should 😉
I can live with that for now.
JP.
@Jefffromtexaswrote:
IFTTT doesn't work for me either-Android.
Are location services enabled ? Did you give IFTTT location pernissions ?
I can't see why it would work on my end and not on others... screenshot shows IFTTT doing its job today.
JP.
I have an Arlo Q, not a Q Plus but the regular Q does not show up in the dropdown menu for this reply. I have an iPhone 7. My geofencing does not work. The camera is arbitrarily armed when I'm home and disarmed when I'm away. I have disabled the phone in my Arlo app geofencing menu, saved, reactivated and saved again. No improvement. I only have the one device that I need the app to recognize. Using a schedule is not a good option for me as my schedule changes week to week. I would at least like to know which radius size is considered optimal although I've tried all three with no improvment. The community entries I've read seem to indicate that this feature is just not implemented well by Arlo. Please let me know if there's anything else I can try and if there are fixes in the works. Regards.
On my Galaxy S7 it works fairly well as long as I've freshly opened the app. The app seems to forget what its supposed to be doing but seems functional even though its not. I have to kill it and reopen it and geofencing works.
Hope they get out the fix for Android soon.
