Before last app update, every once in a while, the Arlo iOS app would report that my base station and cameras were offline, even though everything was up and running. After a few seconds, the app would cycle back to online mode.
After last app update, there is a lot of "Your device is not connected" errors, all the time. And it takes forever for it to cycle back to correct online mode. This is very frustrating when something is going on outside, and you can´t access a live video feed, when everything is connected and up and running.
- Arlo iOS app
 - iOS version 13.6.1
 - Arlo appversion 2.19 (990)
 - iPhone 11 Pro
Jessica
Myself
IOS app not functioning correctly. Firefox appears to be working OK
Iphone XR OS 13.6.1 and Ipad Pro 13.5.1
Aelo app version 2.19
Experienced on both devices
Firefox 79.0 on macbook pro. OS 10.14.6
I have the problem as well. Started yesterday (8/20/2020) accessing via web browser. My system has 2 Ultra cameras which now show device not connected and 3 older Pro 2 cameras which are working fine. Previously, one of my Ultra cameras would stop recording & live streaming, but restarting the base station would resolve the issue, but a restart no longer helps.
iOS version 13.6.1
Iphone X
I'm using Arlo app on iOS 13.6. Indicates "connecting" ... takes 1 - 6 minutes to connect, then loses connection.
Also, instead of camera view of video feed, I get what looks like window venetian blinds almost all the time. Can someone help me? I'm using the Arlo updated iOS app. If I can't resolve this, I will return the camera.
The day started out fine, with no errors. This afternoon things are going downhill. Fast.
Now it´s the second time the Arlo iOS app has shown ´Your device is not connected´ for much longer. First it was gone for 30+ minutes, now it´s been out for 10+ minutes.
If I log on to MyArlo via my Win 10 computer, I get access.
The biggest problem is that my iPhone is my primary device in my Arlo Setup. I don´t bring along my stationary computer to check Arlo when I´m out of my house.
For iOS users experiencing this issue, please force close and relaunch the Arlo mobile app. The development team is working on a permanent solution for this issue, we will provide an update once that solution is available.
Thank you; do you have an ETA on this?
Having the same problem after installing latest update 2.19. iPhone 11 pro - iOS 13.6.
App is virtually unusable on the iPhone. Takes random times up to 10 minutes before the "Your Device is not connected" message leaves the camera windows and the cameras can be accessed. Have been using Arlo cameras for a few years now and have had few problems during this time.
Can access the cameras via a Mac desktop computer as an alternative but this only useful if I am at home.
Appears there are some serious bugs in this latest App revision . Perhaps Arlo should give consideration to rolling it back until they figure out what has been broken.
Hello.
Others (https://www.reddit.com/r/arlo/comments/iegv3h/this_started_happening_daily_it_takes_about_30/) and I are having this "Your device is not connected -- Make sure it's connected to your router and has a working Internet connnection." and other problems. I see it a lot in my old iPhone 6+'s iOS app. I even uninstalled, redownloaded, and reinstalled the app but still saw the issues. Internet, base stations, cameras (still dected and record), etc. were fine. 😞
What's up? Thank you for reading and hopefully answering soon. 🙂
and “base station offline” but on my IPad it works perfectly.
iPhone is connected with the WiFi and reinstalled the app, with no result. Has anyone this problem solved?
With every miss-managed software version upgrade you continue to affect your customers safety & confidence in your product! Now with version 2.19 as of August 8, 2020, this is our message... “Your Device is Not connected”. How can your Development team NOT beta test software BEFORE its released? So how long do we have to wait this month before it’s fixed?!
1. via the web It’s fine.
2. via IPad it’s fine.
3. Via IPhone it’s This ERROR message “Your Device is Not connected”!
There's a review of Arlo Pro 3 today on Norwegian tech site, tek.no: https://www.tek.no/test/i/y3Qb62/arlo-pro-3-er-god-men-ogsa-skikkelig-frustrerende
It adresses the errors of the last days, with a sudden change in app language and notifications to German, and the current problem with unstable connections to cameras. Both issues cause the journalist to give a lower score in overall.
I have been an Arlo customer since 2015, first with the original Arlo cams, then moving on and upgrading to Arlo Pro 2. Now I'm in the process of upgrading my remaining Pro 2 cams to Ultra. I have experienced a few glitches in the matrix along the way, two defect cameras (replaced on the spot by shop), and a firmware update that causes on of my cams to go on software vacation.
But nothing like the situation now, so I am hoping for a rather quick solution to this issue, otherwise I will have to seriously consider not upgrading my last Pro 2 cams to Ultra, and looking at other options.
Hoping I'm not ending up there, because Arlo system and cams, are fantastic at what they do most of the time.
I have the same issue; it started immediately after the last Arlo update (a few days ago) and is persistent. I have restarted the base station, router, and uninstalled and reinstalled the Arlo app on my iphone 6 with no good results. The only thing I can add to what has been reported is that the only phone/tablet device that is used with my Arlo system that is affected is my iphone 6. My win10 view is not affected, my (very old) ipad mini view is not affected, my wife's iphone XR is not affected, and my wife's (older) ipad view is not affected. All 4 Apple instruments were updated to their respective current operating system versions prior to this problem and they still are current.
To add to it, despite stating “your device is not connected” on my iPhone (11 pro max) the cameras still record and alert motion AND work just fine on my iPad when the two devices are side by side, so they are in fact connected but the iPhone app has trouble recognizing that. This needs to be fixed, otherwise these cameras are worthless as you cannot view cameras or change the arm modes when this occurs.
same issue hier sinds update app last week 2.19 app says cams offline but stil receive notification and when entering on webbrowser everything's ok.
I had the error when i first updated and I forced closed and restarted the app and have not had it happen much since. Once in while and i would get it then it would go away after a few seconds. Like a mod posted before Arlo is aware and working on it.
Same issue here with 2 of my 11 cameras. Works fine via the web and they still operate properly, but the iPhone app always shows them as disconnected.
Same issue here. Random "your device is not connected" messages even though the system was working fine until recently and nothing has been changed. As you rightly indicated its yet another poor, untested firmware upgrade.
We are in a wild fire zone in Senoma and about to leave, just when I needed my security cameras.
And Please Arlo tech, don't ask me to get in touch to resolve the issue, I'm a comms engineer and not stupid - the issue is poor QA/PA and no amount of resetting and cable changing is gonna help.
Why are you requesting your user community to debug for you? Before you release any changes to Apps or firmware you should be thoroughly testing and if you need help, releasing a beta for feedback. What you should not be doing is relaesing changes before you, Arlo, have done your job.
How hard can it be?
Forcing a close doesn't solve the issue. Just the usual bla bla from you guys at Arlo.
Instead of putting your customers though so much pain, why not revert to an issue of software that works. And don't blame IOS, all my other Apps have somehow managed to continue working fine. This is just down to Arlo incompetence.
The suggested temporary fix of force close and relaunch of Arlo app did not solve this even temporarily for me. Please fix this soon!!!!!!
						Accessing Local Storage
1  -
