Apparently, this problem is widespread based on what I am reading as known issues.
Are you still experiencing this issue?
No details.
It's working here. We need details for what you see and what you've tried. Check your active mode. Reboot your base. try both the app and a browser.
I have five cameras and all are working but 4 have stopped recording. I have tried turning off and back on. Internet up, all green lights on base.
Have you checked your active mode? What are the motion icons for each camera in the Devices tab showing, black or gray? Gray means they're disarmed.
I think I've figured out the problem after much trying! I might need to buy a new battery.
Don't forget the 1 year warranty. Open a case with support:
I bought a new battery and that did not fix the problem, so I did an online chat with ARLO support and they helped me. Had to take the battery out of the ARLO camera, leave it out for 3 minutes; disconnected base and left it off for 3 minutes; restarted both; re-synced the base; then re-synced the camera and it works great now. Didn't need a new battery but now I have a backup. Hope this helps. (when you re-synch, make sure the base and camera are within no more than 3 feet of each other so they can 'talk' to one another.)
Resyncing cameras is just busy work. The problem is on the arlo backend/firware/data centers. Nothing we can fix. Arlo engineers need to go back to school or to school for the first time and learn to code, test, debug, and fix.
My cameras slowing stopped recording. First one and then the other. Batteries show 100%. I can view LIVE but motion doesn't start them recording. Suggestions?
Hi, my camera settings shows that recording is ongoing. However, i cannot access any of the recordings. can you please assist me?
