Apparently, this problem is widespread based on what I am reading as known issues.
Ot ıs wırwles wıth lights
some of my cAmeras stop recording. I havle 2 separate station with total of 6 cameras. 5 on one Nd one on the other so far onl 2 of them are recording rest of them does not, what she’ll l do?
Yes l am still having this issue
@ShayneS wrote:
Hi @muallasm12
Have you tried to reboot the cameras by removing & re-inserting the batteries?
O I have not, l just got the cameras 7-8 weeks ago l am trying to learn how to resolve the issue
Can you check the web browser and see if the videos appear in your library?
I would suggest starting with a reboot of the base station & test again.
I will also supply the link to customer service, in case you would like to contact them.
I do Che k the library continuesly it does not show any widens except two cameras. Not only that there was an attempt to break in my house only my front door camera recorded, although they were going all over the front yard which l have additional two cameras beside my front door. To day l was my back door it did not recorded either
When did the two cameras stop recording motion?
I Would suggest starting with the 1st step above
- "I would suggest starting with a reboot of the base station & test again."
return/sell it's your only chance and buy nest or something that acutally works
No recordings or footage comes up after a notification of movement on both the lap top and phone . The cell phone has "Getting Statas" on screen .. Any help ??
Ive had the Arlo Ultra for 3 weeks and I have the same issues. Arlo released updates and the software is junk. Ive been adjusting, resync, reset, to no avail. Return it before its too late!
Hi @juggy1
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech support
This product (Arlo Ultra) I think was released too soon and the software is buggy.
It should "just work" for $1500!
I have a Gbit Network at home with Wireless AC and 5G Android Pixel 3XL.
These cameras are not ready for Consumer use IMO
Hi @78Stallion
Sorry, that question was intended for @juggy1. May I ask what issue you are experiencing with your system/cameras? I would be happy to assist you.
I am having the same issue. No recordings but am receiving notifications. I recorded manually and it appears but at the top where it tells you how many recordings on a certain day it still show 0 even though when you open the day the manual recording is there.
When recording manually the video count will not be displayed in the video counter aree you are referring to.
Good to know. The real issue is that I am receiving notifications, there are deliveries and other intrusions and noe of them are appearing in the library. It may be that I will need to reset the hub and resync which I will try when I have access. I did a remote reset of the hub and one of the cameras has started to load video clips to the library. Hopefully the rest will as well.
same issue here. one of my camaras is recording i already try all your suggestions.
Arlo please help!!!
not recording!!!!!
Arlo please help ... I already turn it off. take battery and nothing works
Ive done everything, everyday for 3.5 weeks.
Im returning them before its too late.
The Ultra is not reliable or ready for release!
