Apparently, this problem is widespread based on what I am reading as known issues.
Can you provide a little more context regarding the issue you are experiencing?
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
I have opened a case for you. Customer Support will be reaching out to you as soon as possible. I have provided the case number for your reference: 41112362
I am also having this problem with 2 base stations, a VMB4000 (2 years old) and a VMB3500. Can see live streaming and hear audio when cameras are on, but there is no recording in the Library. We just added the VMB3500 and several new cameras. They were working okay, and recording in the cloud. I had an issue with Firefox and Flash (now resolved) but Library videos were viewable on mobile devices (IOS and android) and on desktop using Microsoft Edge. We haven't had any videos recording since September 9th, several days after the new install. This has been very frustrating. Four of the cameras are difficult to access, so I am hoping for a solution that doesn't involve resyncing them.
I'd start by seeing if you can make a manual recording from each camera.
If that works, then double-check that the mode for both base stations is armed. If they are armed, then I'd try restarting the base stations next.
Hi @StephenB All but one camera is recording. The camera has worked fine up until they all stopped recording. I have removed the rechargeable battery cube and relinked to the base station. I also reset the base station. I am able to manually record. No recordings appear in the library but I do get alerts.
Hi @wsuraci
In addition to switching off after the restart I removed camera and base station from my Network then restarted all over again adding base station and camera!
Bingo all successful camera is a wirefree device!
Good luck
Thanks for sharing your experience. The two cameras that were not sending pictures to the library did send some today (the first time since they were installed more than 2 weeks ago, and about 1 week after I reset the base stations.) Arlo technical support has been in touch and I think if they can help me shorten the time between when motion is detected and the video recording begins I'll be all set. Hopefully the recording won't be intermittent.
Hi @Psw88
@Kityeo wrote:
I getting notifications but no recordings to the Library
What cameras do you have?
@StephenB I have only one camera
I removed all devices using Arlo app then removed the Netgear router
Starting again app searched and found router then once that was set up searched for my one and only camera
result success notification via email now has a link to the recording(s)
hope that helps!
May I exchange 2 cams for one camera with continues recording?
Firmware:1.14.1.1_2913_78b189a Hardware:VMB4000r3 OS:iPhone 7
I did not receive videos or notifications in my library. I deleted the Arlo app and reinstalled it. Rebooted the base station. I started receiving notifications but was not getting videos in the library. I went to the Arlo LIve Online Agent. The agent had me power down the base station for 2 minutes. After base station boot up I started receiving both notifications and videos.
Front door camera not recording. Plugged to station, full battery. It does capture image when walking by it, does not send notification.
Not recording any movement! but work when live.
what else do you need to know does not record
So your answer to fix the problem is remove the cameras and reinstall.
seriously, why don’t you refund the money and I’ll go buy a blink system:
Neighbors have a blink system about as long as I’ve had my Arlo they haven’t experienced any of these problems with their system.
thank you for your time.
I'm having similar problems, I actually didn't realize the cameras were not registering any content (motion is still operational) until I was out of town checking on the residence. I've done the basic troubleshooting techniques from restarting the base station to individually turning on and off cameras, and so on.
If there's a simple fix please let me know...
Much appreciated.
I did not remove the cameras. I deleted the ARLO App and reinstalled a fresh version from the App Store. I shut off the base station for 2 minutes and then repowered. I was given this advice by the Live Online Arlo representative.
Thanks for the heads up, I'll give that a try. I was considering removing all the cameras and reinstalling them (but this is the last thing i would like to execute).
